Steve_in_C
My water temps in NC will sometimes reach 60 ifor a few days n Feb and then go back down. I use a mesh cover. Typically the last week if Feb or in early March I will stake the pool to shock level FC and then check it about once every 2 weeks. I start the pump running 15 minutes a day. No daily chlorine additions. The cooler temps and the cover make the chlorine last a long time. In this case, almost 6 weeks. CYA of 40. Pool always has a lot of pollen when I open, but no algae. Started in the beginning with TFP methods and have never seen in algae in my pool. If you see algae growth every year with opening you need to start chlorine earlier. I keep a floating wireless thermometer in the pool and the base unit reads current temp all the time. That makes it easy to monitor.
