Hi, new here. I had a new pool service person add PoolRx to my pool a few months ago. Almost immediately thereafter I noticed several rust-colors spots on the bottom of the deep end of the pool, which I have been unable to remove with a brush---haven't tried the vitamin C method yet, but planning on doing so. In addition, I have noticed a yellow/green film on the sides of the pool, which can be scrubbed off, but results in the water becoming slightly cloudy, and seems to reappear a few days later.
My question is if I ask the pool service person to discontinue the PoolRx, as it seems nearly guaranteed to be the culprit given the timing proximity (had not had any staining in the 8 years of ownership prior to PoolRx), is there anything else that I need to do to remedy the stains? I'm thinking that simply discontinuing the PoolRx will not magically reverse the stains on the bottom and film on the sides, and likely more servicing is needed. Photos attached of the stains on the bottom and the film on the side.
Apologies in advance that this is likely a dumb question, and thank you so much for any guidance/help.
