Poolmath/TFP time not matching
:unsure:Did you put the correct date when you were logging in your test results in the PoolMath App? Usually, the current date is displayed for you upon entering your results. I can't figure out why future dates will be displayed on your log report. I'll let someone chime in here shortly about this. May be a technical error, but check regardless if the date you entered in your log in the poolmath app is correct.
The times are shown in universal time however SHOULD automatically convert to your local time. I stress the word should however as clearly the Java isn’t working right. Only users who are viewing your logs on a webpage are seeing the wrong times, all your data on your app should be correct.
Viewing my logs on the web on a computer is nice because it's BIG, so I noticed the time difference as well today, but I just thought I was so good at pool maintenance that I was able to do things in advance.
