- Aug 12, 2016
- 28
- Hayward Aqua Rite (T-15)
Hi!
I'm currently in the process of opening the pool. Temperatures are still too cold for my SWCG to work properly, so I'm currently treating the pool as a chlorine-bleach pool.
In the app, pool is currently setup as a SWCG.
My last test, FC of 7.5, CYA 50.
How come the app is recommending FC of 2,0 - 8,0 ?
As per Chlorine/CYA chart:
Shouldn't the app Recommended FC be at least 4, since it's the 1st value in the chart for SWCG?
Also, for pool owners that need to play with both NON-SWCG and SWCG pool setup, would it possible to have something in the App to help us? Or should I just reconfigure the pool as NON-SWCG until I turn on SWCG unit?
Thank you!
Christian
- NON-SWCG with CYA 50, min is 4, target 6-8
- SWCG with CYA 50 is not there, CYA too low
Thank you!
Christian
