Hello All. Having some problems trying to maintain chlorine in my 20,000 gallon pool with vinyl liner. I have a Hayward heater but haven't needed it lately. I have an inline chlorinator but it's been turned off as I've been trying to get my CYA down.
Problem started after a few vitamin c treatments to help with iron staining. Vitamin C works like magic (added polyquat 60 during treatment), followed up with Jack's Pink Stuff. Stain comes back once I add any amount of chlorine, but I've been putting in a bottle a week of Jack's Blue and that seems to keep it to a minimum.
I have dumped more than 50 percent of my pool over the past few weeks - attempting to reduce cya and iron content. I got my cya down from over 100 to 65. I know, still high, but hoping to get a new liner next season and full dump and will never use pucks again.
Anyhow, I've dumped 3 cases of cal hypo and at least 8 bottles of bleach into the pool (four bags at a time, or two bottles at a time). Can't get a reading above 1.4 or 1.5, even a few hours after shock treatment. I know I'm probably not adding enough based on my high CYA.
My question is: Can someone help me calculate exactly how much chlorine I'll need to SLAM? I have a case (12 bags) of cal hypo 73%, four bottles of 12 percent liquid chlorine and a few bottles of chlorox.
Here are my current readings:
FC .4
CC .4
PH 7.1 (using ph meter - might be a little lower on color chart using the drops)
TA 100
CYA 65
using TFT test kit
Thanks for all you do!
FC .4
CC .4
TA 100
CYA 65
using TFT test kit
