Hi all. Was just taking the compost out and I noticed the walls on both sides of the above-ground pool were buckling in. Looked closer and it appeared the weight of the snow was putting too much weight on the cover, pulling the walls in a bit. We live in Vermont and get plenty of snow but have never had this problem since we bought the house and inherited the pool three years ago.
Started shoveling off the snow, finally peaked under the cover and there was only about 6-8 inches of water left in the bottom of the pool. Had left it at about 3 feet, just a few inches below the filter trap when we closed it for winter. We were able to get all the snow off, dumping some of it into the pool as we went and the walls all popped back to normal as we removed the weight and the cover. I'm assuming we have a hole somewhere and once it's patched and the pool is full again we won't have to worry about the structure.
But I could use advice on what to do with the now mostly empty pool for the rest of the winter. If we put the cover back on as it was, taut, I'm guessing I'll have to shovel it off and remove it partially for every snowstorm here on out. Can I leave it off completely? Just drape it over the bottom and secure it so it doesn't blow away? In both cases I know I'd be starting from scratch with the chemistry in the spring. Or should I turn the water lines to the hose spigot back on and try to fill it back up to where it was? I probably have 2-3 more months before we're opening it up for the spring.
Thanks!
Thanks!
