Hello, we had a few tiles pop off of the spillway of our pool. Having done some research it sounds like I may need ez-patch 1 (to build up the bed, where the tile will be placed), ez-patch 3 (thin set) and ez-patch 4 (grout).
We recently had a freeze and I’m thinking (hoping) that is the reason for the tiles popping off. I don’t see evidence yet of any cracks or anything.
I’ve already used a little saw to remove the grout on the tiles. The tiles look like they are in good shape. I also removed the grout on the sides of the tiles that bordered the ones that fell off. But I’m not sure whether I should try to chip away the grout or plaster that was underneath. I saw a pool video where the person doing the repair simply built up the bed (using EZ patch 1) to make the surface even without chipping away anything underneath. That person then reapplied the tiles using the thin set and then grouted around the new tiles.
My questions are, should I chip away the gray stuff in the picture? I don’t know if that is grout or part of the bed that I should build back up using EZ-set 1. If I do chip that gray stuff away, then do I even need EZ-set 1 or can I just use EZ-set 3 to apply thin set to the tile and then just use EZ-set 4 to grout around it? Just wondering what the experts would do…
