This is my second season opening my pool (I bought the house in July of 2017). Late last season, after using too many tri-chlor tablets I had some chlorine lock problems and some very high CYA levels. I attempted to recover with a partial drain and refill with limited success but it was late in the season to be using an unheated pool in Vermont so I lowered the water level by about 2 feet and closed the pool for the season.
We had enough rain and snow since the fall that the pool level is right back where it should be and I decided to start the opening process last weekend while the water was still pretty cold (high 40’s) and before it had a chance to develop much algae.
The first thing I did was grab my Taylor K-2006 Test Kit and ran some tests…
PH = 7.2
TA = 100
CC = 3.2
CYA = 45
My first question is about the chlorine level. Without having added chlorine since last September I was surprised to find chlorine in the pool. Is this normal? Did I have enough CYA to stabilize the chlorine for the past 8 months? Granted, I did add massive amounts of chlorine last August and September when I was struggling with chlorine lock.
My second question is about my CYA level, which after my chlorine lock problems I am very sensitive about. When I did the CYA test I took my reading after I couldn’t see the black dot with a fair amount of effort (ie, if I could see it with a bit of effort I kept adding more of the mixed solution to the comparator tube). Is this the correct approach? I don’t want to under estimate my CYA level.
FWIW – I added three pounds of Cal Hypo and ran the pump/filter for 24 hours and saw significant improvement in water clarity. When I first uncovered it I could see the bottom drain but not the pattern of the liner, after 24 hours I could see the liner patterns so apparently three pounds of Cal Hypo was enough to make a difference which would tend to suggest that my CYA level is ok, right?
I’m tempted to bring a water sample to the local pool store to be tested with the ALEX system so that I have something to validate my testing against but I’ve heard mixed things about the reliability of ALEX.
TIA!
PH = 7.2
TA = 100
CC = 3.2
CYA = 45
TIA!
