Date is important, and storage method too. If they have the 10% sitting out in the sun and/or it is old, it may not be stronger than the 6%.
So earlier in the week I bought several bottles of the regular bleach at Walmart that has 6% Sodium Hypochlorite for under $2. Then today I went and looked in the pool section and they had Pool Essentials Chlorinating Liquid for almost $4 a bottle but it had 10% Sodium Hypochlorite. Is one better than the other? Would you recommend I stick with the cheaper stuff even knowing the strength is less?
Yes, until we prove no SLAM Process is needed.Water is NOT green and has been clear for days now. So, are you saying to ONLY add bleach for now?
I'd bring the FC up to 10 (test after dark for the starting FC number and you can do a CC test then) and conduct an Overnight Chlorine Loss Test tonight.
If you pass Overnight Chlorine Loss Test, .5 or below on CC and clear water then it's time to adjust to your goals.
I guess my questions would be, Why did you want to raise your CH and TA. Where did you get your target numbers?
TFP uses these numbers as your target:
Vinyl Pool with Bleach
FC 3-7 (See [FC/CYA]chart[/FC/CYA])
pH 7.2-7.8
TA 50-90+
CH 0-350 (Don't add)
CYA 30-50
So, of your numbers the only one I would adjust might be CH to the minimum the heater manufacturer recommends. I though that was usually around 200 - 250, so you are or are almost there.
I got the targets from the calculator on this site. I just left the "target" number as is. The only number I changed or did anything with was to add my actual number. This is why I ask to make sure I'm doing it right. To make sure I'm doing it right.
Ok, going out to add the chlorine now and will follow the additional directions. Will 1 gallon (10%) suffice to get me there do you think? Thanks!
HOLY COW!! She's a TESTER!!!!
You can use the Pool Math to play around with figuring out if you need to add 5ppm then you would add x. That is how I figured out 1/2 gallon for me is 5ppm.
I am so happy for you, those numbers LOOK GREAT!
Add that chlorine, leave your filter running for the next day or two and lets test the FC in about an hour!
Good Stuff SummerTimeGirl!! Good Stuff!
LOL I am so excited!! I anxiously awaited UPS ALL day!!! Yup, put a gallon of 10% in already about 20 min ago and will go test in about another 40 min and then again tomorrow am before it gets too light out. You and everyone else have been a great help to me!!!!! Thanks so much!!
You are right, it's better to ask.I got the targets from the calculator on this site. I just left the "target" number as is. The only number I changed or did anything with was to add my actual number. This is why I ask to make sure I'm doing it right. To make sure I'm doing it right.
Sounds right, but if your CC is 1.8 that is a fail. Let's see where everything is in the AMOk, so I think I did this right.
FC - took 17 drops or 3.4 (#drops x 0.2)
CC - took 9 drops or 1.8 (#drops x 0.2)
Is that correct?
Is that correct?
Ok guys, so at hubbies insistence I went back outside to retest. He swore up and down that I did not allow the powder to totally dissolve and wondered if that mattered. I didn't think it would but went back out anyway to appease him. LOL But this time (after making sure it was dissolved) the numbers were...........
FC - 15 drops, or 3
CC - 4 drops of 0.8
So take it for what it's worth I guess the true test will be in the am. Thanks guys!!!
haha us dang husbands, always getting in the way! lolol
I don't recall, did you order the speed stir as well or you doing this by hand?
Either way, those numbers certainly are closer to what I personally would have expected from everything we have discussed and the pictures you have shown.
Yes, lets see what it says in the morning.
This is so exciting!!
LOL Right?
No, I did not get one of those speed stir things so for now I've just been trying to swirl it the best I can. Eventually I will spring for one of those.
And yeah, it's exciting as long as the algae is gone. LOL Not trying to battle that junk again.
