I put up my 16x10 Coleman Above Ground Pool yesterday but Forgot to put one of the legs through the strap around the pool.. all the other legs are good. Can this cause problems? The pool is full.
You may want to add a rope around it from the legs on each side just for peace of mind then correct the issue when u need to drain water. For what its worth i’ve seen many people have broken straps so as long as the pool & legs are level & not moving you should be ok until u drain & remedy it.
