- Jul 21, 2013
- 66,811
- Plaster
- Pentair Intellichlor IC-60
Thank you. Attached is how the pool was originally drawn for permitting although when building we removed the 4th pump and idea of swim jets. Is this configuration doign what you're describing - one pump for filter and heater (going to spa jets) and a dedicated spa jet pump (labeled here as a booster)? Do they literally pump to the same pipe at some point in their circuit? That's the way the concept looks to me.
It looks like it does but the devil is in the details that are not shown for it to function correctly.
Water from the filter and heater pump should not go to the spa jets. There should be one or two spa returns on the walls close to the floor.
The spa jet pump is not a "booster." It provides all water flow to the spa jet from a dedicated suction line in the spa floor or wall.
