- Oct 25, 2020
- 106
- Plaster
- Pentair Intellichlor IC-30
Hi everyone -
Last weekend, out of nowhere, my spa water was super low and stagnant. When I went to activate "Spa Mode" in iAqualink, nothing happened, so I manually moved some actuators to get water flowing into the spa. Since then, every time I think I have it solved, I'll wake up and the spa is drained again. But it never drains all the way, it just loses about half the water (see photo).
I'm guessing I have an issue with the actuators and not fully understanding how to position them. Can someone help me with my plumbing and the proper way to set this up. My two questions would be:
- How should it look when I'm in "Pool Mode" and the water is circulating across both pool and spa. If I put my pump high enough I'll get spillover on the spa into pool
- How should it look when i'm in "Spa Mode" and the water is confined to the Spa with jets on?
