Hello,
So I am having a little trouble with a cloudy pool and slightly green film on bottom of pool.
I was all fine until some really hot weather and rain. I really never had an issue until I used these 3" Pucks so Im also curious if there is a Chlorine lock somehow. just at a loss....Tried clarifier but didnt do much, back washing every day sometimes twice a day.
Its an above ground pool vinyl liner 26,500 gal. and chlorine pool
Water Temp 82 degrees
Sand Filter running at least 12 hours a day
Just did a test and came back with:
PH 7.5
Total Alkalinity 24
Free Chlorine 7.7
Total Chlorine 7.7
CYA 78
Hardness 97
I know the levels are a little low in some areas like TA, and Hardness. But question is do I SLAM to clear the water? And do I correct the levels before a SLAM?
Thank you,
AF
PH 7.5
Total Alkalinity 24
Free Chlorine 7.7
Total Chlorine 7.7
CYA 78
Hardness 97
Thank you,
AF
