Since I purchased the house last year, I have been using Leslie's Pool product such as Leslie's Pool Shock "Fresh and Clear".
However last month I noticed little green algae on the wall. I went to the store and they told me that my phosphate is too high. Then purchased the Phosphate reducer. Issue is corrected.
My attention is to try other brand since Leslie brand was not killed algae/not effective for me. Should I switch to Clorox Pool&Spa Shock Xtra blue from Costco? However, I heard that it contains small copper (not sure if Leslie also?). It will stain the pool if weekly used.
Now I am confused. Which other shock products that I could use without copper? Or my perspective about all of this is not correct?
Thank you.
Thank you.
