Hello,
We had pool school yesterday with our brand new build. I learned a lot, but water chemistry was very light in coverage to say the least.
Pool Details:
in-line chlorinator
11k gallons give or take
Stonescape minipebble plaster applied March 12
We ventured out yesterday to buy the following pool chemicals. Please let me know if we don’t even need some of these so we can return, not sure with having the in-line chlorinator:
4 gallons liquid chlorine
3” pucks
Soda ash
Hardness Plus
Muriatic acid
Shock packets
Conditioner
I ordered the TF100 test kit awhile back and we did our first full chemistry test this afternoon. The results:
FC 5
TA 50
CYA 30
PH 6.8
CH 225
CSI -1.32
I inputed all this into PoolMath app and immediately wanted to address the PH first, so I sprinkled 2 lbs 2 oz of soda ash into the pool just now as directed by poolmath.
I then wanted to address the calcium hardness, but I was reading the directions on the chemical packaging and it said to not add the same day as soda ash. Is this true? I held off on that to be sure. I’ll try that tomorrow I guess? Do I need to do another full chemistry test before I do tomorrow?
I then moved onto my TA, but realized we do not have 5 lbs of baking soda, so I’ll grab that tonight or tomorrow morning. Again, do I do another round of tests tomorrow before?
My CSI has me worried as it suggests corrosion could occur. Is my CSI calculated based on all the other chemical levels? If so, I’m assuming that once my other chemicals get brought into range, this will normalize?
Any other things I’m missing? My free chlorine is kind of on the high side, so should I dial down my in-line chlorinator a bit, too?
Any help or pointers y’all have would be greatly appreciated. I’ve been reading on this forum since pool construction began and have learned sooooo much valuable information. Wonderful resource. Thanks again.
Pool Details:
in-line chlorinator
3” pucks
Soda ash
Hardness Plus
Muriatic acid
Shock packets
Conditioner
FC 5
TA 50
CYA 30
PH 6.8
CH 225
CSI -1.32
