Pool Quotes - Melbourne, FL
Catching up....busy, busy, busy settling into Florida....
Framing and Rebar...
More framing and piping...
Gunite!
Reactions: NickCYC and JamesW
Remove framing and back fill. They actually back fill then re-dig up for the piping.
More back filling, pipe dropoff, lay piping, and tile work.
Piping and Grading
Spigot for inside cage and Spa Tile...
Footing prep and footings...
Pad, Coping delivery, coping install...
More coping work, grout...
Found out there was an issue with the pool. It was dug to high. The slope from the coping to the lanai would be to high. The lanai pavers which we were not replacing had to come out so they can raise everything up. Ended up getting the same pavers now on the lanai which in the end looks good.
Pavers complete. They did have to come back later and replace some and some other touch up work.
There was an issue in that the pool was not square to the lanai so they did have to add more footer to the left side.
Cage work...
Equipment Drop off, hookup (no electric yet), cage wires for picture window, and initial drain and cleaning.
Now waiting for mosaics to show up, cleaning, acid wash, electric for equipment, Intellicenter, auto valves, lights, aggregate finish, back filling, grading around the outside of the cage, mudding the backside of the pool wall outside the cage and painting it.
NICE! Thanks for catching us up!!
So who took the $$ for the pool being too high and having to redo the patio?
No one will even notice the extra bit of tile in that area. At least they caught it and fixed it.
Why??? Why did they feel the need to drop the equipment there?? sigh........will they pay for for the new grass?
They gave us a good discount on the matching pavers, they took the labor. They will pay for the re-doing of the grass and grading, it should have moved down though. First pool build. We plan on putting a cinder/conrete block wall to the left of the pump to defect any noise equipment noise. Updated signature with some design stuff...
