I have a 15k gallon pool. The pool is holding water well, no leaks or water level dropping (The water level is important due to the bubbles - see below).
I got a pump problem. These pool pumps are made by Centurion Model B123 and Centurion Model B625. Neither of these pumps have been rebuilt. I would assume that one pump runs the jets and the other pump runs the Polaris.
I went out today and realized that none of the jets in the pool were moving water while the Polaris was on. When I turn off the polaris, i have 1 jet moving water albeit slowly. I have another jet with sporadic bubbles coming out. the other two jets aren't doing anything.
I am curious to know what your thoughts are for the lack of water movement through the jets as well as course of action.
I am not adverse to rebuilding one or both pumps if you think it will fix the problem or if it would be better to get a new pump.
Thanks for your help.
