Hello all,
I Love that I finally found this site. I have been looking everywhere for some direction. I'm starting a pool build and am trying to get all the equipment that will make it all work. I have a gunite rectangle 16' x 32', 3.5'-7' deep pool with a 16' x 9' cabo shelf.
Plumbing Layout all 2" pipe
- 2 x Skimmers
- 1 Main Drain
To - Pentair IntelliFlo VF Variable Speed Pump
To - Pentair System 2 DE Filter PLDE48 with Backwash valve
To - Solar Heating panels at 15'
To - IntelliChlor Chlorine Generator - IC40
To - 3 x 24" waterfalls & 3 Deck Jets & 4 bubblers in the shelf
To - Pool Returns and at least two near Cabo Shelf to keep the debris off
No Heater or Spa
So the question I have is can this be done with the single pump or do I need another one for the water features. I understand that if I have the water features running the pool returns are going to suffer with alot of pressure lost. For typical cleaning cycles, I don't have to use all the water features. Any input and or wisdom would be greatly appreciated. If there was a similar question please direct me with the tread. Thanks
- 2 x Skimmers
- 1 Main Drain
No Heater or Spa
