Pool pump timer not working
nityntiy
115
Dallas, TX
My timer is not working lately. I have it completely turned off but the pump still runs when the power is turned on. Only way to shutdown the pump is by turning off the main power. I haven't changed any settings, everything is set to Auto except Heater. How to fix it?
Its Compool LX-100 POWER CENTER.
You can swap the pool pump timer with the cleaner timer to see if the timer is at fault. Be sure to shut off all power to the pool panel at the breaker before messing with it.
Most likely the timer contacts are stuck/welded together. You may be able to unstick and carefully sand the contact to get a bit more life out of your present timer. Timer replacememt is about +/- $70 online.
