We had a bad storm in our area last Friday which dumped loads of leaves and branches in the pool. Took hours to clean up! The baskets both in the skimmer and next to the pump were jammed tight with leaves and twigs.
My problem is that now the suction generated by the pump is way down on what it was prior to the storm (insufficient to drive the pool vac around even on max RPMs). I tried backwashing but this didn't help.
I'm assuming that as the problem only started after the storm it is likely due to leaves and debris in the pipes.
Any suggestions on the best way of dealing with this kind of problem ? Is it OK to use a plumbing snake on the pipes ?
Any help appreciated !
