- May 3, 2007
- 18,099
- Plaster
- Hayward Aqua Rite (T-15)
Yes, although you can put the air line inlet almost anywhere. Mine is at the edge of the deck about half way between the spa and the equipment. It is only about 10' from the spa so it doesn't "need" a Hartford loop and can clear the lines on it's own but it is always a good idea to put one in anyway just in case. The issue with air lines is that if they are really long and the entire pipe fills with water, when the jets are off, then it is almost impossible to clear the lines without a blower. On another forum, a builder mentioned that he was able to design an air line over 100' long without a blower. But of course he used a Hartford loop. BTW, where is your equipment pad relative to the pool location?So is the air line ran all the way back to the equipment pad and just left open (unless a blower is added)? I think maybe that's where my confusion is. Also is there a hartford loop at each jet or 1 for the entire spa?
A "plumbing loop" is a completely separate loop of plumbing from the suction port through the pump to the return ports. Usually each plumbing loop will have a separate pump. A "separate return" may use the same suction lines and pump as another function but from the pump back to the water, the return lines are separated for individual control.When you say "return loop" does this mean basically having a dedicated return run all the way back to the pump inlet with a valve separating each return before entering the pump (sorry trying to understand terminology)?
Only if you add actuators to the valves.When doing automation I assume you have to have control over both the return and the supply side.
YesI assume it's probably a good idea for each water feature to have it's only supply valve as well especially if doing different sizes and types of water features (for example 2 different lengths of sheer decents)?
Even if she says no, assume yes. It is 100x more difficult to change things after the fact.I'll have to ask the wife if she would like to have the water features run while in the spa or not
YesSo in this case the spa would have it's only return and supply lines and they jets would operate independently?
YesWhen you said "if you want filtering for #3, #4, & #5 all at the same time" you basically mean if we want to have the spa heating, the water features on and circulating the pool we would probably need 3 pumps and 2 filters.
Here are some standard configurations: Jandy Valve Plumbing Schematics - INYOPools.com
