- May 5, 2024
- 2
- Vinyl
- Pentair Intellichlor IC-40
I currently have a single speed whisperflo and going to replace with variable speed whisperflo. It’s a drop in replacement. As you can see in pictures, it has 2 unions but not directly next to pump. I can unscrew unions, unscrew pipes directly in old pump, re tape plumbers tape and screw into new pump. There are currently no leaks on existing pump connections there. Or should I buy 2 high temp unions and re-plump? The 2nd options seems more work but not sure recommendation. Thanks
