HI all,
I'm looking for recommendations for a new pool pump. I have a Hayward Super Pump (1Hp), that has recently decided to stop working. I think the bearings are seized. I can't turn the impeller, even when I've removed the motor from the wet end. I had been interested in upgrading to a variable speed pump for the purported energy savings and now seems like the time ( I might pull the old pump apart and rebuild it later).
I have a 20x40 foot pool with an avg depth of 8ft. I have a Hayward sand filter with 3.1sq ft of area (63GPM), a Titan Titanium Heat exchanger, and 2" pipes. I have 2 return lines and a main drain, a skimmer drain, and a vacuum port. How do I know what HP is sufficient (I felt circulation was maybe a bit weak) but that wont be overkill. I was thinking about the Hayward Super pump VS but had a company quote me on the Pentair Intellipro VS at about twice the cost. Thoughts?
