- Jul 3, 2023
- 44
- Plaster
- Pentair Intellichlor IC-40
Hi all, I have run into an interesting problem with Pentair Easytouch. I have set up two schedules for the VS 3.0 Pump. One is called "Pool" and the other is called "High Speed". High Speed is a feature. I am trying to run the pool at 1500 rpm for 6 hours (Pool rpm) and 3 hours at 2700 rpm (high speed). What I see happening is that in the "pool" schedule, the pump relay kicks on, SWG gets power and it runs. In the high speed schedule, for whatever reason, the "pool pump" relay is not activated and SWG does not get power and does not run - but the pump is running at high speed. Is this a wiring issue or expected behavior? I was hoping that ad t "high speed", the pump relay is activated and SWG can run during both schedules.
