Below is a pool proposal from a builder that we are seriously considering. All feedback is welcome. We are very interested in hearing thoughts on the builder's suggested equipment. The design is not quite finalized, but I will post it when it is. The builder is very experienced and has a good reputation, but they're a "production" builder so I want to be sure that we thoughtfully consider everything.
- Pool Size: 15' x 30' Gallons: 15,150
- Perimeter: 90' Area: 450ft2 - We are modifying the pool to a "lazy L"
- Pool Depth: 3.5' - 6'
- Engineered Construction & Plumbing Plans and Building Permits
- Pre Grade and Site Preparation
- Removal of existing paver as needed
- Pool Layout and Pre-site with Customer
- Form Pool, Excavation with Hand Trimming and Shaping
- Steel Reinforced 4000 PSI Pneumatically Applied Concrete Structure with Reinforced 8" Bond Beam, 6" Walls and Floor, including Seven Irons, Perimeter Wrap, 3/8" Steel Rebar 12"O.C.
- One (1) Set Shallow End Entry Steps w/ 5'x6' Sun Shelf
- One (1) 4' x 18" Underwater Bench
- Two (2) LED Underwater Pool Color Logic Lights
- Choice of 6" x 6" Frost Proof Waterline Tile installed w/ mudset
- Lifetime Warranty Interior Pebble Pool Finish
- Removal of Wood Forms and Backfill and Grading for Pool Deck
- 60 linear feet of Channel Deck Drain
- 720ft2 Brick Paver Decking set w/ Polymeric Sand & Bullnose Brick Paver Coping
- All Heavy Gauge Schedule 40 PVC Plumbing w/ CMP Channel Main Drain
- High Flow Surface Skimmer pre-plumbed w/ pressure test and formed into gunite shell
- High Performance Smart Flow Pump
- Extra High Capacity 225 SF Micro-ban Smart Cartridge Filtration System set on a poured in place Concrete Slab
- In Line Chlorination Tab Feeder System OR 20,000gal. Capacity Aqua Rite Salt Chlorine Generator System
- Five (5) Return Line Total Recirculation System
- Pre-plumbed Pressure Line for Pool Vacuum
- Complete Electrical wiring of all components
- 24 Hour Mechanical Programmable Time clock
