- Jul 23, 2014
- 59
- Vinyl
- Autopilot Digital PPC1 (RC-35)
Low cell volt warning light came on today. I cleaned the salt cell even though it didn't look bad. Here are the #'s from the control panel.
Salt: 2700ppm need to add 52 lbs
Volts: 3
Amps: 4.7
Hours: 29160
Temperature: 79 deg Although the thermometer floating in the pool reads 87 deg
This is on a Pool Pilot Digital nano plus. Model 75043. The pool and equipment are over 4 years old.
I will add salt tomorrow. Not sure if low salt can cause this warning. Otherwise, owners manual noted that it could be a bad power cord. Not sure what else to look at.
Thank you for any assistance.
Volts: 3
Amps: 4.7
Hours: 29160
