- May 23, 2015
- 25,795
- Plaster
- Pentair Intellichlor IC-60
Water is seeping into the main drain area and into the pool from the hydro-static valve.... as expected. However, there is always a little bit of water sitting in that little "cup" in front of the line that runs from the main drain to the skimmer. If I vacuum it out it fills up again right away, but it never keep flowing... just sits in that little cup at the bottom of the main drain (at 5 o'clock in the picture below). If it helps, I can take a video and send it tomorrow. I think it is more than condensation because the water flows into that little cup immediately after I vacuum it out. I was able to pump water out of the pool using the main drain, so it was drawing water from the bottom of the pool through that line.Is that water in the drain coming from the pipe?
Any chance it’s morning condensation ? Especially being all slick with the fresh paint any drops would probably find their way there.
Yes.... I was told that if that line gets damaged the only economical thing to do would be to seal it off. I am posting another video. This one is from inside the skimmer. It looks to me like there is water sitting in the MD line, even though I have the vacuum running from the other side of the MD line while I am taking this video. Even if there is some kind of leak, I wouldn't expect to see water sitting in that line. Seems very odd. Also..... I was able to pump water out of the pool using the main drain when I was emptying the pool. Wouldn't that be hard to do if there was a break in that line. I know last summer I was able to draw water from the bottom of the pool, so at least it wasn't damaged to the point of being completely non-functional.Sounds to me like your MD line between the drain and the skimmer may have a tiny leak. If you can rent a bore scope you can try to find it but otherwise you may need a leak professional to come out to find it. Some drain repair plumbers can do pipe fixes in place but typically in old pools when the MD has a leak, the drain simply gets sealed off and you lose it. Bummer.
Your video is marked a private it tells meNo.... even later in the day when the pool is dry there is water there constantly.
I have been popping open the hydrostatic valve periodically and vacuuming up the water that comes out (in order to keep the bottom of the pool dry), but it is spring loaded, i.e., it lets water seep into the pool when pressure builds up. If I haven't opened it for an hour I start to see water seeping out of the valve, then I open it and vacuum. Isn't that spring-loaded mechanism the safeguard against possibly floating the pool... or causing any other damage?By the way, make sure you pop that hydrostatic valve open ... you don't want to accidentally float the pool.
Changed to public and re-posting video.Your video is marked a private it tells me
Was planning to start filling the pool this evening. What should I specifically be looking for until then? Right now the line coming into the skimmer and the "cup" at the bottom of the MD both remain bone dry. I am taking a last look around before I start filling the pool. I put the pool light back in, but snapped the picture below before doing so. Does this look problematic at all? I think the pool company took care of a leak in the light fixture a couple years ago. I see that "putty" (shown in photo below) all around the inside edge of the pool light housing. Looks like a pretty good seal all the way around. Should I add some where the wire goes into the pool wall.... or does it look okay.... and what the heck is that stuff and where do I get it (if needed)?Leave it open and monitor it for a day or two. See what happens.
