Any idea how much chlorine I'll likely be adding daily? I'd like to stock up the liquid but not sure how much to get?Pool all freshly filled! Started chemical add yesterday.. Added 1 gal Muratic acid split in 1/2 - 4 hours apart per directions. Calcium was low so added 25lbs Calcium Hardness split between 2 doses, 4 hours apart. This morning added 46oz of Sodium Hydroclorite. 4 hours from now, will add 3lbs 13oz Cyanuric Acid in split doses 4 hours apart per directions. Plan on waiting 24 hours before retesting. Does this sound about right? Will then start testing CH & PH daily and full kit weekly.
