Pool mechanical timer lever is turning off when the computer settings are supposed to have it running...
stevesimon
1
Spring Hill FL
my pool has a tan control box and timer. and it is a salt pool with a white salt charger control box. the pool filter has a computer screen which controls the functions of the filter (all units are Haywood). The unit is getting shut down and when i go out to see why the manual lever in the tam boc has switched off. I turn the lever to ON and it's back on. Should I just remove the two ON? Off stops that are on the time wheel in the tan box?
Search instead for my pool hase a tan control box and timer. and it is a salt pool with a white salt charger control box. the pool filter has a computer screen which controls the functions of the filter (all units are Haywood). The unit is getting shut down and when i go out to see why the manual lever in the tam boc has swithced off. I turn the lever to ON and it's back on. Should I just remove the two ON? Off stops that are on the time wheel in the tan box?
Which Hayward pump is this?
If the time clock (most likely an Intermatic T104) is also controlling the SWG, the wire to the pump should be moved from terminals 2 and 4 on the clock and placed on 1 and 3 so the pump has constant power but the SWG is turned on only when the pump is running. You have to program the pump separately from the time-clock settings.
If you are not familiar with working with high-voltage electricity, hire a pro. Your first mistake can also be your last.
