Pool math has a place to enter the temp as part of your test results
Go into settings and enable track water temperature.
Then in the test results you can choose C to enter your results
If you make the change in the CSI it’s playing “what if” it’s not actually changing the underlying temperature recorded - you have to do that in the actual test data field for the temp
Thanks, yes I do track water temp and do enter it in Celcius. But in the CSI tab it still defaults to Fahrenheit. I'm just wondering if this is affecting my CSI?
I remember that I had that issue, too, at some point. It took some random switching between gallons and litres in the pool settings, closing and restarting the app, and switching between pools, until I had Celsius back to default everywhere. Don't know what it was that fixed it eventually.
