I am trying to configure the Pool math app for my pool. In the set up for pool type you only have 3 choices: plaster, vinyl, or fiberglass. If you have a gunite pool with a pebble tec finish, what is the best choice? I assume not plaster. Thanks
Thanks. I assume while the pool has a plaster base, the plaster does not interact with the water because of the coating. Just wondering if the set up in the app is just asking pool type as a demographic type question or if the pool type will change the ranges for some of the readings (such as CH)
