- Apr 25, 2016
- 81
- Plaster
- Pentair Intellichlor IC-40
I have been using the Taylor Watergram calculator for about 4 years. I like the convenience of the Watergram. I have seen the Pool Math calculator and have sort of played with it a little but it wasn't until today that I noticed a difference between the two calculators. Is it me or is there a real difference?
Here is my example:
POOL MATH
FC 6.0
CC 0.0
pH 7.3
TA 60
CH 550
CYA 50
BORATES 50ppm
TEMP 80
CSI -0.48 (Corrosive)
Taylor Watergram
Same numbers as above:
CSI -0.05
Can someone check this and let me know if I am doing something wrong! Can there be this much of a difference? If this is the case, my numbers are out of whack and have been for years. This would explain the episodes of scale and pitting in the plaster. I can't believe the huge difference between the calculators.
I would like to figure this out before I close in a few weeks so I don't open up to any more surprises.
Also, I have never checked my water after closing the pool, should I? I figured there was no way to circulate the chemicals so why bother with it. What do you all do?
Here is my example:
POOL MATH
FC 6.0
CC 0.0
pH 7.3
TA 60
CH 550
CYA 50
BORATES 50ppm
TEMP 80
Taylor Watergram
CSI -0.05
