Here are today’s readings on my freshly filled pool. Pool math app says to add 5 lbs of dry acid and pool store says add 2lbs and to not use muriatic acid as it will damage the vinyl liner, how much to add ?
Also
Installing bigger sand pump tomorrow as the one bought with the pool isn’t big enough. Do I start adding chemicals knowing that we’re going to have to drain it down to change out hoses to fit me pump?
Also
