What is a good solution for under water lights that is wireless? We no longer can use the standard deep end light
I have two solar lights from LedecSun.What is a good solution for under water lights that is wireless? We no longer can use the standard deep end light
These are great! Thanks for the idea. Exactly what I was looking for. I may start with one to see how much light it providesPulled them out tonight, lit up nice and bright as expected. Can't wait to drop them in the pool in a few weeks!
Did you attach these using the adhesive that they provide? How easy are the lights to remove without damage to the vinyl liner? Thanks!I have two solar lights from LedecSun.
Pool Lights Without Installation - LedecSun
Light up your pool with our wireless pool lights. Solar spotlights that are easy to install without having to empty your pool.ledecsun.com
They are plenty bright but are a bit pricey at $250 each. They come 2 color options, white or deep blue. I attached a pic of my pool at night (deep blue).
The lights come in 2 mounting options....built in magnets for steel wall vinyl liner pools or adhesive for pools other than steel wall.Did you attach these using the adhesive that they provide? How easy are the lights to remove without damage to the vinyl liner? Thanks!
Do you think the adhesive will damage the liner? I have a liner pool with polymer walls, so the magnet version won't work for me. I'd like to be able to take them off in the winter time for storage, but don't want the adhesive to damage the liner. Hoping it's something like that mounting putty you can use to stick posters to a wall.The lights come in 2 mounting options....built in magnets for steel wall vinyl liner pools or adhesive for pools other than steel wall.
The lights have strong magnets that allow you "stick" them to the walls and remove them without damaging the liner.
Easy to put on, remove, and adjust without any concern.
The adhesive is for pools that are constructed without steel wall panels.
