Hello!
I'm trying to troubleshoot a light issue. It would trip the GFCI outlet immediately after turning on.
I shut off the breaker, checked the wiring in the junction box, and it looked like moisture got in the box.
I cut the ground and binding wires and stripped them to expose clean wire, then I cleaned the connections with a wire brush. (I'll need to find a new gasket for the box, of course). No change. I pulled the light from the pool and opened it up, and found some moisture inside. The gasket mating surface is not clean, looks like old gasket material so I'll have to clean that off, too.
I let it sit in the sun for a while, and now it turns on, but then it will trip the GFCI after a few minutes. Pretty sure if it was still wet, it would trip immediately.
I noticed the GFCI outlet is 15 amps, but the breaker in the panel is 20. Could that do it?
I'm trying to do everything to get it working before I just put in a new light. I'm going to replace the GFCI outlet, and I'm thinking of pulling new white from the junction box to the outlet.
Thanks for any advice!
Patrick
Patrick
