Bought my house almost 2 years ago and it had an inground pool that was built in 1983. The single pool light worked fine and was plenty bright for the smallish pool. The night I was closing the pool last fall, I turned on the light and it flashed then went out. I figured the bulb burnt out and I would deal with it in the spring.
Well, it’s spring.
I pulled the fixture out today and it’s an old Anthony model with a small halogen bulb... I was hoping it was a standard threaded socket and I could replace with an led bulb... but no such luck. The ge bulb that was in there has a 1983 date code. Impressive life span!
Anyone know of a way I can use this fixture with an LED? If not, is there a fixture that would fit this niche I could wire in?
thanks!
Well, it’s spring.
thanks!
