Hello, is there a reason why many manufacturers stick with 12V AC for the pool lights instead of the 12V DC? One of my 12VAC transformer failed, can I use a 12V DC?
From exprerience with LED bulbs, most of them that I use in my various projects works both 12V ac & 12V dc since they have an embeded rectifier bridge.The quick and dirty answer is "No". They're not interchangeable.
Maddie![]()
So, the main reason choosing 12V AC is for delivery, efficiency and economy as you suggested, and not for extra safety. Do I get it correctly?Its not the voltage but the amperage you need to fear. You can hold a spark-plug wire that hits you with 40,000 volts (DC) and it will hurt like crazy, but won't necessarily harm you (been there.) The actual current is milliamps (one or two thousandths of an amp).
A lethal shock can be as few as .06 (six-hundredths) of an amp at any voltage AC or DC. That's why we do everything possible to keep electricity out of the pool water.
If DC diminishes much quicker over distance than AC, why are the longest transmission lines DC?They are using 12v ac for the same reason we us alternating current in homes, industry, etc. For one, DC current diminishes much more quickly over distance than does AC.
- The AC is simpler to produce than DC. It is also less expensive than DC to generate.
- The AC systems have higher efficiency than DC such as ac generators.
- The waste of power is negligible for AC during transmission.
No that is true. The most famous example (here on the west coast) is the Pacific IntertieI really doubt that is true..
