Hello all,
The pool was just opened today and it looked remarkably good, picture below. I ran the tests and the results are as follows:
FC: 0
CC: not tested, figured I was going to begin SLAM tomorrow
PH: 7.0 it could be lower but 7.0 was the lowest panel on the tube
TA: 60 - 70, 60 began the turn color and 70 solidified the color change
CH: not tested
CYA: less than 30, tube full and dot was still 95% visible
Salt: 2.1 on the machine and 2000 with the Taylor kit
Temp: 64
I cleared 90% of the organic material out and will circle back tonight to get the rest. I am draining a bit of water now to get the water level to proper skimmer levels. SWCG is set to 00% until I get the other levels straight and then I will run it at 50% like I did last year.
My question is, should I start adding the chlorine or worry about the CYA and PH first?
Thank you!!
FC: 0
CH: not tested
Temp: 64
Thank you!!
