I have an in ground pebbletec pool with attached infinity spa and rock water fall, approximately 14,000 gal. I have a 2 year old Pentair Whisperflow, 2HP pump and a Pentair cartridge filter system with four Filbur FC1978 cartridges that are 1 year old and were cleaned one month ago. I clean them every three months. Pool has a Hayward Pool Vac with a dedicated vacuum line. The pool also has a regular skimmer and a QuikPure Ozone System. The pump runs 9 hours per day, every day of the year (daytime). I use only liquid chlorine and liquid acid. I brush the pool at least three times per week and manually skim almost daily. Both skimmer baskets checked at least every two days. Water hardness here is quite high. Pool was drained and refilled two years ago, including an acid wash. Last summer I used an inordinate amount of chlorine.
The pool always seems to be on the edge of going green. I see green tinges on the walls and the clarity is not the best. Last summer I was always jockeying between high pH and low alkalinity, fixing one and then messing up the other. Seesaw at its best. In one day, the pool can go from looking really good and clear and then, not so clear with green tinges showing here and there. I'm not sure why my pool water is so fragile all of a sudden.
Last year, in frustration, I "slammed" the pool over a three day period. No change. I would hate to drain and refill again but I'm open to anything at this point.
I have a TF100 kit and the results are as follows:
CYA=60
TA=100
pH=7.2-7.5
CL=1.0
Hardness=750
FC=25 ppm
CL=0
What am I missing? The pool man I used to have used nothing but Chlorine tablets and the pool was always stunning and that's before my new pump and new filters. I'm about to surrender...lol.
I must be missing something here.
Thanks for any help.
CYA=60
TA=100
pH=7.2-7.5
CL=1.0
Hardness=750
FC=25 ppm
CL=0
