Hi,
My pool was out of service for a while as I worked on plumbing, adding unions, rerouting pipes, and replacing the sand filter, laterals, and multi-port valve. During this downtime, algae developed, so I began the SLAM process on Monday (26th). However, the pool hasn't shown any improvement; it's still just as green as when I started.
Last Sunday, I added acid to lower the pH to 7.2, then raised the chlorine to about 16 ppm and have maintained it between 16-18 ppm over the past 5 days. I've been testing the water 2-3 times daily, brushing and vacuuming daily, running the robot for 4-5 hours each day, and keeping the pump running continuously. In the past, I've seen the water change color within a day, turning cloudy, but now, on day five, there's been no change.
Here were the levels before starting SLAM:
- pH: 7.2
- TA: 60
- CYA: 40
- CH: 200
- FC: 0
