I have a 45,000 gallon old in ground pool. It was redone approximately 15 years ago, they sprayed a whole new bottom (gunite?) and did tile etc. it’s 3.5’-10’, DE filter system with booster pump for sweep. THAT is unfortunately all that I know about it.
Move lived in my house 18 years and the pool was here when we got it. I was never the pool keeper or chemical girl, my husband did ALL of that. My husband passed away just shy of two years ago, I inherited the pool responsibilities. I have done a pretty good job of educating myself on the pool and workings of the filtration system. Because of my husbands death, my income was cut to 1/5th of what it was so when I say I can barely afford to even maintain the pool, I mean it. Actually, I can’t afford it, my 19 year old buys the chemicals. Anyway, I’ve been able, with the helps of sites like this and YouTube, to do some repairs I had to; that I never dreamed I would be able to do. Hiring someone was not an option. I really don’t have any business having a pool anymore BECAUSE of the money it takes and fear of problems. But I live here and can’t afford to move, and I can’t let it turn into a biohazard. With all that being said here is my MAJOR MAJOR problem:
I noticed about 1.5 months ago that I was having to top it off more than normal. This has gradually worsened. I didn’t notice how bad until today. I guess 2 weeks ago I really started griping about it. Thought it was the heat and evaporation. Water bill came today and was DOUBLE! I remembered this morning as I left for work thinking I needed to top it off so I could turn it on (timers don’t work) but didn’t have time as I had to go. I remember exactly where the water level was this morning. I get home, go out to turn hose on and almost have a stroke, it had dropped down since 8am 2”, the top of my first step was dry. The pump and filter hadn’t been on I’m prolly 2 days. There is NO standing water on or around the filtration equipment or visible pipes. None anywhere in my yard, none anywhere at all that is visible. No cracks in the plaster or whatever - that I can see besides a few hairline ones that have been there for awhile. I’m seriously worried sick. I’m almost screwed, because I can’t hire someone to troubleshoot much less fix, this problem. As of right now, I don’t see a way to keep from just letting it go. Some of you are probably thinking I’m dramatic, but I’m not. I’m a widow, living paycheck to paycheck and things like this are theView attachment 82682 reason I think of moving and renting now and then. I’m desperate.. I need help. And it may be, most likely is, much more than I can handle, but I figure I have to try.. Thank you...Amy
(The photo is 3 years old)
