Hello,
I am a new homeowner and it came with a pool (~28,000 gallons). I just had it opened two days ago (Long Island, NY). I noticed that the water levels are dropping; over 1.5 inches in the last 24 hours. I have called to have the guys try to locate/fix the leak. My question is, should I even bother to add chlorine, CYA at this point?
Here are my test results using Taylor's kit:
CYA -- basically zero
Free chlorine -- 0.8 ppm
Combined Chlorine -- 0.2 ppm
I know I need to add these things to bring the values within the ideal ranges, but should I wait until the leak is fixed? I don't want to waste chemicals...
Thanks for your input.
