I need to drain for TDS, but my pool is a little green. It is not a swamp and I can see the bottom at 10ft. Just soupy, some algae on the walls, and enough leaves that it will fill up the pump screen quickly. Should I drain before bothering with any clean up, or SLAM the pool with the old water then drain? I suppose if I drain without the slam I will still net the leaves out, because that seems easier then cleaning them up off a dry pool and I don't like delaying the re-fill in any temperature.
Thanks in advance!
Thanks in advance!
