- Nov 11, 2020
- 172
- Plaster
- Pentair Intellichlor IC-40
I'm not sure but I will confirm. Should I be concerned about any issues with my plaster both aesthetically and structurally due to them plastering before my equipment was installed? I'm going to continue brushing and trying to keep the ph and Ca hardness within range but until my equipment is installed, that's about the best I can do.Ok! got it.. once you get your kit.. post up your first set of results.. and we will guide you from there. Do you know if your PB will be providing some start up maintenance? many do for the first 30 days to ensure the plaster is within warranty. If not we can walk you through that too.
