22,000 gal pool, Hayward cartridge filter, new vinyl liner, running filter 24/7, Ohio. Pool water is crystal clear, chemicals are all balanced. The only thing that is low is water hardness but I’ve been told that is not causing the issue. Every few days I will see green spot on the sides. I add 2 bags of super shock, brush the entire pool, exchange the filters and soak in super shock, add algecide. We’re good for a couple of days and then spots again. Follow the same procedure again and we’re good for a few days and spots again. I’ve been doing this since I opened the pool. The pool stores test my chemicals and are also at a loss. Thought the algae might be hiding somewhere that I missed. Took the ladder out and scrubbed every inch. Continue to have the same problem. After shocking and cleaning and vacuuming and doing all of this when I take my filter out to change it it always seems to have a green tinge. Soak and exchange and still happens. Where is this ages hiding?
