- May 3, 2014
- 62,781
- Fiberglass
- Pentair Intellichlor IC-40
You have a sand filter. They work fine. Just need to be ready to deep clean it in the spring. It has unions so will not be a big deal.
Single speed pump. You did not show a label for the motor but it will consume about 1kwH per HP. A VS pump would be a good investment. You another pump for a pressure side cleaner. There is a line after the filter that feeds it.
Remove the copper insert in the blue thing. It is adding copper to the water. You do not want that in there.
