- May 31, 2012
- 854
- Vinyl
- Jandy Aquapure 1400
My pool has a Jandy Lite 2 pool heater from 2006 that looks like this:
This heater also works as the control for the pump, including a simple timer that allows for one off time and one on time per day. The heater also has the smarts to keep the pump running for five minutes after the heater shuts off so that the burner cools down - and it shuts the heater off five minutes before the daily off time.
The heater isn't working and the repair guy suggested that it needs to be replaced as there is a lot of rust and he said "most of the refractory material has disintegrated and collapsed onto the burner tray. Due to the high cost of the refractory kit it is not advisable to repair this unit". He doesn't sell heaters so he has nothing to gain from telling me to get a new one - in fact he would make more money if I told him to repair it.
It is my understanding that not all heaters have the electronics to control a pump. Any suggestions on what to get to replace my heater?
My pool shop has suggested a Raypak heater, but I don't know that they control the pump. Ideally I would like a heater that can be controlled by a smartphone app or other Home Automation system, but I don't want to pay more than $200 for such functionality. (As an aside why does it cost so much to put "smart" functionality into a pool system when the hardware is not dissimlar from a Raspberry Pi Zero that is worth about $25 (including peripherals).
Note that I have a solar heating system so I like to run the pump from sunrise to sunset. I live in Toronto and the pool is open from early May to early October but I don't heat it during the beginning and end of the year unless the weather is good. During the summer I like to keep the pool at about 84F with the solar and gas heaters. I have a Control4 Home Automation system so I could use that to trigger a relay to turn the pump on and off.
edit - I forgot to clearly state that I have a NatGas heater and that is what I would like to buy again. My pool is about 100,000 L so I think I need a heater that is at least 250,000 BTU. Is it worth getting a larger heater? What are the advantages of that? Just faster heat up times?
