Pool frog leak
JD-Harley
1
Chester county pa
My pool frog chlorinator is leaking from behind the intensity dial. I saw in an old thread someone suggested just pulling it out and replacing the o-rings. Is that possible. Do you just pull the dial out? Any more specific instructions. Can you get the o-rings from the manufacturer? Any help is appreciated. Thanks
Good morning and welcome to TFP! :wave: We don't normally use the Pool Frog because of the potential side effects (metals) to the water, but I did find the link below which illustrates the O-ring replacement options. Looks like those should be a fairly simply DIY project.
We recommend reviewing our Pool Care Basics page for lots of great info and let us know if you have any questions. Enjoy! :swim:
Can you just remove the whole thing? That would be ideal as it’s use is not recommended.
Take some pictures of your equipment area.
