Was hoping for advice on how to handle the below situation. Pool is a Capri Resin/Steel 15x31x52 with a Unibead52 liner (pretty sure I ordered the thickest liner available). Pool was installed in May 2018. Over the past couple years I've noticed a couple of areas where pool floor was sinking (at pool floor - wall & it seems to be at the vertical pool supports).
Well this summer as you can see from the photos below, I've noticed where the floor has sunken about 2 inches and now is stretching the liner against the pool hardware. In the last month it's gotten worse (as you can see in the photos).
Did the installer not compact the sand enough in these areas and now it's sinking? Can I put a patch over this current problem area (any underwater patch recommendations?). Or is this a ticking time bomb and I am looking at a new liner/compacted sand by next spring?
Any help or guidance would be greatly appreciated.
