Hello All,
I am a brand new above ground pool owner (27' diameter, 18,500 gallons, sand filter). I have been reading pool school and working to clear my pool but am not having any luck so far. I am attempting the SLAM process, and so far the water has turned from green to blue, but is *extremely* cloudy. I would guess you can not see down more than 2-3 inches. My skimmer bucket is always empty, and there are no debris in the pool at all that you can see. However, when I run my robot on the pool floor, it always comes up with pine needles and leaves (quite a bit usually). I believe the previous owners left the pool uncovered so I am worried there may be (a lot?) or organic material on the bottom. I tried vacuuming but there was nothing in the skimmer (I am not positive I had good suction). Maybe I should backwash and then try to vaccum again?
Here are my latest numbers from this morning:
FC: 19.5 (was 24ppm when I went to bed last night)
CC: 1.5 (was 2ppm when I went to bed last night)
TA: 140
PH: 7.2
CYA: 70
CH: 250
Temp: 82 degrees
Thanks and I would appreciate any advice on how to clear up my blue but extremely cloudy pool!
TA: 140
PH: 7.2
CYA: 70
CH: 250
Temp: 82 degrees
